Hello All, I need to replace the tires on my 2016 Lexus ES350.  The current Conti Pro Contact didn't even last me 30k miles.  I would appreciate recommendations.
Thanks
Nik
I put Yokohama YK740 GTX tires on my car, supposed to have 60k treadwear. Coming up on 10k miles for me and so far they've been great.
What are you looking for & / or what is important to you in a replacement tire?
Also, what is your tire size?
That will help in narrowing down your options.
:cheers:
Continental PureContact LS tires tested tread life (Consumer Reports outside-tested) is 75,000 miles (if rotated every 5000-6000 miles). These are categorized as "performance all-season" tires.
There is a category for Ultra High-Performance tires but that is probably not necessary for an ES.  Now if you'd like even higher mileage in the Performance All-Season category, Michelin CrossClimate2 tires are rated for 85,000 mile life.
 If cost is your main concern General Altimax 365 AW tires are also recommended with a tread wear life rating of 60,000 miles.
Of course, you'd have to check to see if these manufacturers make tires in your size.
