NYLEXGS Posted May 20, 2004 Posted May 20, 2004 I just installed an SRT intake on my 99 GS 400 with the ECU. I am running on stock exhaust. After installing it, I took it for a test drive and a couple of times while doing about 15-mph the car shuts off. I drove over a speed bump and the car shuts off then I had to put in the neutral and restart it. I know SRT says you have to drive 250 miles before u see max. performance. But I was woried if this is a problem or is it just the engine and computer getting used to the ecu and the new setup.......any advise, thanks.
SKperformance Posted May 21, 2004 Posted May 21, 2004 You may bnot have tightened something like the battery or maf sensor properly.
RanGer498 Posted May 21, 2004 Posted May 21, 2004 check your work sounds like a loose wire some place ..i hope you dint just use t taps or strip and wrap the wires ... i suggest you solder and use some sort of shrink tubing as well ;) and reset the ecu too.
