Kendrick Abraham Posted May 20, 2022 Share Posted May 20, 2022 I Have A 1995 Ls400 ,So I Replace My Alternator 3 Times And I’m Starting To Realize That I Have A Massive Oil Leak All Over The Alternator,I Check the PS ,That’s Not It ,I Change The Valve Cover Gaskets And Still I’m Getting Oil On My Alternator,Can Someone Help Me Please Cause I Can’t Keep Goinh Through Alternators Anymore ???? Quote Link to comment Share on other sites More sharing options...
RX400h Posted May 20, 2022 Share Posted May 20, 2022 I believe you can add a UV dye made for engine oil. Once everything is cleaned, you would check your engine, frequently to spot the oil seepage using a UV light. Finding Oil Leaks with UV Light - Did It Myself (did-it-myself.com) Quote Link to comment Share on other sites More sharing options...
