Sc300 Rear Shocks
Group,
how easy is it to change the rear shocks on a 1997 SC300?
I am a pretty good DIY person.
How involved is it? Is it really as easy as unbolt the old and bolt in the new?
Does it change the alignment?
Tom
As long as you dont have TEMS or some other crazy suspension it should be just bolts. The only hard part is if you dont have a spring compressor to get the spring off of the shock. I think i paid $10 for one at Wal-Mart. Just make sure you have a 1/2" socket or a large breaker bar. Those suspension bolts may have been there for the last seven years and might not want to come off that easy
If its for the rears it shouldnt affect it. Your camber may be off depending on how long it has been like that and wether it was adjusted with the bad shock or not. For peace of mind you may want to get it done. One less thing to do later on
