rdpoint Posted February 17, 2022 Share Posted February 17, 2022 I have an 08 RX 400h, the bracket on the front right side had a seized pin, who ever did the brakes did not put any silicon on either pin. I wasn't able to get just the bracket so I had to replace the entire caliper. In doing so I changed out the hose as fast as I could but I'm sure some air got in there. I've bled the line twice now and still have the lights on in the picture. I read some of the other posts in here, and it was usually just air in the lines, but I can't get them to go off, the breaks feel fine, my wife says they feel slightly spongy, but the feel ok when I drive it. Any ideas? Quote Link to comment Share on other sites More sharing options...
RX400h Posted February 18, 2022 Share Posted February 18, 2022 Have you checked for codes? You'd need a code reader to do that or you may be able to have an auto parts store check for you. Dealerships and some independent shops typically have a tool to cycle brake control modules. I stopped self-bleeding my brakes when the process required such tools (even in 2001 for my Corvette). Quote Link to comment Share on other sites More sharing options...
rdpoint Posted February 18, 2022 Author Share Posted February 18, 2022 I have not checked for codes, I was hoping to not have to, and that a simple bleeding of the brakes would fix the issue. I'll see if I can't track down a scanner to read the codes. Quote Link to comment Share on other sites More sharing options...
