Just bought 2005 gx 470.  Every light in dash is on. Tried to hook a scanner to and will not connect to ECU.   Runs and drives will not restart until you pull the 2 ECU fuses.  Then will restart.
You bought the vehicle that way? I think I would've walked away from that one. If pulling the fuses disconnects the ECU connection, that may indicate that the ECU board is dead.
