Deshun Posted January 13, 2022 Share Posted January 13, 2022 2002 Lexus RX300 But oh there's SO much more that isn't working... What it's lost: Door chime (doesn't recognize the key is inserted and door is open) Dome light (doesn't work with door opening, however the individual little lights on the bottoms of the doors still work when opened) Door locks (Neither the key fob or the switches work inside) Door windows (They all work individually, drivers controls drivers, passengers controls passengers, but drivers will not control passengers) Automatic climate control system (Backlights work but controls are unresponsive) MPG computer in center screen does not register anything Exterior temperature gauge ECT Snow button does not work Drivers seat belt warning doesn't work (passengers does) Engine temp gauge remains on "C" I keep seeing this issue online but no one ever posts the solution. 😞 Quote Link to comment Share on other sites More sharing options...
RX400h Posted January 13, 2022 Share Posted January 13, 2022 So did everything just stop working or have these issues accumulated over time? Has the car ever been flooded? Quote Link to comment Share on other sites More sharing options...
Deshun Posted January 13, 2022 Author Share Posted January 13, 2022 All at once. It happened about a few weeks ago but then after a few days everything went back to normal. Checked my fuses and they’re all fine. im also dealing with the battery draining as well now. 🤯 Quote Link to comment Share on other sites More sharing options...
Deshun Posted January 13, 2022 Author Share Posted January 13, 2022 And now it’s never flooded. Quote Link to comment Share on other sites More sharing options...
Needrx300help Posted November 28, 2022 Share Posted November 28, 2022 Did you ever get a fix for this problem? I just experienced the exact same issues. Quote Link to comment Share on other sites More sharing options...
RX400h Posted November 28, 2022 Share Posted November 28, 2022 Hello, Jeremy. I suggest that you have your battery load-tested. Having lots of failures, simultaneously often points to a failing battery or bad ground connection. Make certain your battery cable connections are secure and not corroded. Quote Link to comment Share on other sites More sharing options...
