dommm Posted November 21, 2021 Share Posted November 21, 2021 I think I need to replace one or more wheel speed sensors & am looking for any tips that would make the job easier? Thanks Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 22, 2021 Share Posted November 22, 2021 Straight forward job, One bolt to remove the sensor from the wheel hub, Follow the wire back to connector, Disconnect and reverse the procedure to install. 1 Quote Link to comment Share on other sites More sharing options...
dommm Posted November 22, 2021 Author Share Posted November 22, 2021 16 minutes ago, dcfish said: Straight forward job, One bolt to remove the sensor from the wheel hub, Follow the wire back to connector, Disconnect and reverse the procedure to install. Thanks for your reply dcfish. Are all 4 sensors identical? I have been googling the issue & am having trouble finding my exact model (2004 Lexus ES330). It seems on some models the front & back sensors are very different looking. Thanks Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 22, 2021 Share Posted November 22, 2021 The wiring may be of different lengths. They may be the same sensors on a Toyota Camry of the same years 😉 Quote Link to comment Share on other sites More sharing options...
dommm Posted November 22, 2021 Author Share Posted November 22, 2021 14 minutes ago, dcfish said: The wiring may be of different lengths. They may be the same sensors on a Toyota Camry of the same years 😉 Here is what I am referring to when I say they look different. Thanks Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 22, 2021 Share Posted November 22, 2021 If you are having questions and want facts, Call a Lexus Parts department and verify the parts you need and there part numbers and cost. Then you can research for a better price. Quote Link to comment Share on other sites More sharing options...
dommm Posted November 22, 2021 Author Share Posted November 22, 2021 15 minutes ago, dcfish said: If you are having questions and want facts, Call a Lexus Parts department and verify the parts you need and there part numbers and cost. Then you can research for a better price. Gotcha, Thanks Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 22, 2021 Share Posted November 22, 2021 You Bet... Quote Link to comment Share on other sites More sharing options...
