JerryownsaLexus Posted November 9, 2021 Share Posted November 9, 2021 My 2002 ES 300 is giving the ABS Code 278 which indicated an open circuit in the ABS Solenoid Relay. I have the Lexus Service manual 1&2 for this specific vehicle and the manual indicated this Solenoid Relay mounted in a ABS Relay Block (Sub Assembly). And the service manual indicated the area this relay block is located. I have looked for this relay block and cannot find it. I’m seeking someone with experience that knows where I can find the relay block. According to the service manual this relay block houses 2 relays, one relay for the ABS motor, and one relay for the ABS Solenoid. It also holds a single fuse. Anyone know the specific location of this ABS Relay Block(Sub Assembly)? Did Lexus/Toyota possibly change the location of this box? Quote Link to comment Share on other sites More sharing options...
RX400h Posted November 10, 2021 Share Posted November 10, 2021 You might want to also check with a Lexus parts department person who can look it up in his or her computer. There could've been changes that happened after your service manual was published. Quote Link to comment Share on other sites More sharing options...
