Having Misifiring issues codes are P0307,P0308
arung19
Hi guys any one can help ,having issue with misfiring codes are P0307,P0308,...checked injectors are ok,checked plug plugs are black darken....coils are also fine...every spark plug getting current ....
Edited by arung19
Injectors send for testing and clean up ....was done good .
Put new spark plug ....
Coil getting spark...tested
All the plug are coming black
Computer pull out the codes P0307 and P0308
I'd eliminate the coils being the problem by switching them over to other cylinders and seeing if the misfires move as well. Check that the spark plug's gap is set correctly (1.1 mm), check for compression (spec is 142 minimum PSI 178 nominal PSI- you can rent a compression tester free at most auto parts stores), and check that there is no source of a vacuum leak, especially towards the back of the intake, since that's where both 7 and 8 are located. I'd also check the spark with an in-line spark tester to see how strong the spark is. A strong spark should be blue-ish in color and easily visible in daylight.
