David mac Posted April 12, 2021 Posted April 12, 2021 When I put my car in reverse drive and 3, the D and the R light up at the same time and the car wont go into 3rd or 4th gear. If I manually shift thru 1st and 2nd those gears are fine when I manually hit 3rd or drive it'll rev up like the trans is slipping. I checked the solenoids they are fine the trans fluid has no metal flakes. Its clean. Anyone ever had an issue like this?
dcfish Posted April 12, 2021 Posted April 12, 2021 How old is the Tran fluid ? Is it low? Too high ? Maybe there is an adjustment for the shift linkage???
David mac Posted April 12, 2021 Author Posted April 12, 2021 1 hour ago, dcfish said: How old is the Tran fluid ? Is it low? Too high ? Maybe there is an adjustment for the shift linkage??? The trans fluid is perfect level. The weird thing is how as soon as the D and R started lighting up together it started to mot go into 3rd or 4th. When I shift thru 1st and 2nd the reverse light goes off it only goes on in the gears that don't work. "Maybe neutral safty switch?" Or ECM?
