When I put my car in reverse drive and 3, the D and the R light up at the same time and the car wont go into 3rd or 4th gear. If I manually shift thru 1st and 2nd those gears are fine when I manually hit 3rd or drive it'll rev up like the trans is slipping.  I checked the solenoids they are fine the trans fluid has no metal flakes. Its clean. Anyone ever had an issue like this?
How old is the Tran fluid ? Is it low? Too high ? Maybe there is an adjustment for the shift linkage???
The trans fluid is perfect level. The weird thing is how as soon as the D and R started lighting up together it started to mot go into 3rd or 4th. When I shift thru 1st and 2nd the reverse light goes off it only goes on in the gears that don't work. "Maybe neutral safty switch?" Or ECM?
