I just replaced the door lock actuators in both the front doors on my 2005. Upon testing, all seemed fine.  Door would lock and unlock with the switch and with the fob.  When I got out and locked the doors, the problem reared it’s head.  When all the doors are closed, it won’t unlock.
 It’s like a security mode engages.  Even the physical key won’t unlock the driver’s door, it just relocks immediately. I can open the trunk so the fob works there.  Thoughts?
  • 3 years later...
My ac  blows cold on the right passenger side but not the drivers side and Ialready had my ac serviced, I was told that the left front actuator door needs replacing on my 2008 Lexus ES 350
  • Like 1
This is not uncommon with older vehicles that are used often during warm months. The actuator in question is not the same as the door lock actuator that is mentioned in the first post.
Most likely, what you were told is correct.
  • 2 months later...
Did you figure out what was happening? I have a 2005 ls430 ul doing the same thing
  • 1 year later...
Here is what my dealer told me:  So we contacted the engineer about the key fob issue and then stated that the side mirror would need to be replaced due to no signal for the fob to lock or unlock the door. The price is $1801.68, it's about  3 days out. would you like me to order it?
I guess the key fob signal somehow goes through the side mirror harness.
