jonny66 Posted August 6, 2019 Posted August 6, 2019 does anyone know where i can purchase a platinum series emblem?
1990LS400 Posted August 6, 2019 Posted August 6, 2019 The part number appears to be PT211-33001 but it was listed as a discontinued part on the Lexus parts websites I searched. If you can't find one online, maybe ask a body shop specializing in repairing Lexus cars. If you still can't find one, I supposed you could remove them from your car. They should come right off if you heat them up with a hair dryer and carefully pry them up. When I had a 2000 LS400 Platinum Series fender replaced in around 2013, the body shop had difficulty getting the replacement Platinum badge lined up correctly. When I took the car back for them to try again, they pried off the Platinum badge they got on crooked with a heat gun and a plastic trim tool. They got the 2nd replacement Platinum badge on lined up correctly. I thought it was odd that the replacement Platinum badges were not exactly the same as the original badges in that they were missing the plastic coating of the original one.
Jon Cooper Posted May 25, 2021 Posted May 25, 2021 Hi I have a couple of factory used ones I picked up a junk yard.
