My first AC Pro recharge lasted 2 years. Next, 1 month. Last, 2 weeks.
Do I trust my dealership with the repair? Or should I seek out a third-party repair somewhere in North NJ?
armcomdes,
Find a good independent mechanic to solve your issue. Obviously your dealership isn't solving the problem, and an independent mechanic will do the job cheaper. You obviously have a leak in the system which a service tech must find first, repair, and then recharge the system. Be prepared for spending some bucks as some of the parts in the AC system can add up quickly if the problem isn't a simple seal. Good Luck!
