AndrewDine Posted May 27, 2019 Posted May 27, 2019 Have a 99 ls400 . 200k Mileage. Transmission was shifting fine with no indications of issues . Parked it for and hour and went to head out , and it seems to not want to shift out of initial gear. Fluid is on level. Checked while hot . Would appreciate any and all help . Andrew
sha4000 Posted May 28, 2019 Posted May 28, 2019 Did you check the level with the car running and warmed up? If so the first thing I would do is a drain and fill of the transmission oil pan with Toyota T-IV.
