Naseem Posted December 8, 2018 Share Posted December 8, 2018 Hi everyone, so I have been trying to fix this problem for almost a month now. When I tried to start the car, I used the multimeter to check for voltge, the battery gave me 12.2V while engine off, with engine on 11.4V. I knew then that the alternator is bad. I got new alternator still not charging. Then I replaced the 120a ALT fuse and everything started working and the alternator is charging the battery with 14.5V , I let the car for a while just to charge up the battery, turned off and went to sleep feeling happy that I fixed the problem. The next day I went to start the car and battery light turned on. Cheked the battery volts around 11.5-11.7v. What should I do next I’m confused Quote Link to comment Share on other sites More sharing options...
VBdenny Posted December 8, 2018 Share Posted December 8, 2018 My guess is a bad cell in the battery itself. 1 Quote Link to comment Share on other sites More sharing options...
sha4000 Posted December 8, 2018 Share Posted December 8, 2018 Yes the old alternator probably damaged the battery. Quote Link to comment Share on other sites More sharing options...
