Dark Horse Posted November 16, 2017 Posted November 16, 2017 Hello All, The right side tail/brake light is out (in the trunk lid). There is a small plastic access door. I can't see how I can extract and install a new bulb, as the access outlet is quite small. Any suggestions? Thanks in advance!
billydpowell Posted November 17, 2017 Posted November 17, 2017 it is like working on your DOOR...... Take the trim panel off.... I did.... James, you may want someone to do it for you, while you watch..
