FsportAWD350 Posted September 28, 2017 Posted September 28, 2017 Hi , i'm new to this forum and i'm driving 2015 AWD IS350 Fsport, got bored and hit the search button for Lexus IS and found this forum, this forum seems to be dead unlike other forum, but its a nice forum setup and layouts. i can answer any of your Lexus IS 2006+ answer Suspension wheel mechanic except Electrical ! thats my car
AnotherLexusOwner Posted October 4, 2017 Posted October 4, 2017 I'm not the one who can answer your question but I just want to say, nice car you have there. Any updates about it?
G Hersey Posted June 28, 2018 Posted June 28, 2018 Hi Trung, I have the same model, and I'm looking to upgrade to 19 inch wheels/tires. Any recommendations? Also, I'm in the Rochester, NY area and would like to know what you are running for winter tires? I think the forum is "Dead" because the IS350 is so dependable and has fewer mods available. I had a 2006 with 140K trouble free miles before I purchased my 2015.
pj8708 Posted June 29, 2018 Posted June 29, 2018 Hi there. You probably already know this, but you should check the fit of the tire to make sure it doesn't rub against the wheel well sides when turning corners. Pa
FsportAWD350 Posted June 29, 2018 Author Posted June 29, 2018 11 hours ago, G Hersey said: Hi Trung, I have the same model, and I'm looking to upgrade to 19 inch wheels/tires. Any recommendations? Also, I'm in the Rochester, NY area and would like to know what you are running for winter tires? I think the forum is "Dead" because the IS350 is so dependable and has fewer mods available. I had a 2006 with 140K trouble free miles before I purchased my 2015. Hi there Gary, 1st i'd like to welcome you Lexus IS family, for 19 inch Wheel there are Pro and Cons option : Pro : 235/35/19 FRONT - 265/30/19 REAR "You might have a little rub at the rear wheel if you carry more than 4 persons when you go over a pothole or a bump if your car is LOWERED like an inch" technically you're fine" CONS : 225/35/19 FRONT - 255/30/19 REAR " This setup is 99% Closed to OEM SPECS its fine weather you lowered or not, pothole or bump" and for the OFFSET, offset is up to the taste of the driver small or big Wheel lip in or out really up to you. Pro : +35 Front and +38 REAR "this offset will look very nice and cool but i afraid the Rubbing when you make a sharp or corner turn CONS: +38 Front and +40 REAR " this one is perfect without issue " Remember our car OEM suspension setup is STAGGER , the front wheels are smaller than the rear by tire and width but Rim diametre are the same. For Winter, let say you wanna save $$$$ and headache, i recommend you to run SQUARE setup Gary, remember the OLD Lexus IS250 AWD setup was 225/45/17 , So for winter storm ice and snow, it is best to used smaller wheel setup and our car can RUN WITH 225/45/17 on AWD, its will be alright and Tire's brand is up to the driver ? some likes Michellin some likes Yokomaha.
