I recently had to replace the inside driver's door handle on my 1992 SC 400. OEM part and now the power door lock won't open completely to make the door open from both the inside and outside. If you push the lock to the unlock position with your finger the door will open. The lock moves when using the remote but just not far enough to unlock. The lock part works fine. Can anyone tell me what could possibly be wrong?
Possibly some linkage not reattached correctly after replacing the handle?
Nope - There are only two cables connecting to the door handle (one for the door and one for the lock and they are impossible to reverse because of the end connectors) and no other parts to the linkage. :angry:
the only other thing is whether the lever where the cables attach is slightly longer which is not allowing the lock to move over enough?
