jmellander Posted May 8, 2017 Posted May 8, 2017 Hi Everyone: I've had a 91 LS400 for several years now (180K miles), and am generally happy with it, although there are still a few minor issues I am hoping to get help with. My first main success was changing out the climate control LCD by installing a replacement one from Ebay - is fairly easy if handy with a soldering iron. Have done a few routine maintenance items, such as changing plugs, but left changing the distributor cap & rotor to my mechanic, when I had them do when they changed the timing belt at about 160K - they said it was the original one, and was cracked, and had skipped a few teeth, making the LS400 run a bit rough.... Anyway, I have a few issues that I hope folks can help me with. I have some info on the fuel pump relay that may help folks, will post on forum. Thanks, Jim
TrevC Posted May 9, 2017 Posted May 9, 2017 Hi Jim....welcome to the Forum sounds like you're on top of all the maintenance tasks...hope you resolve the fuel pump issue. Cheers, Trevor
