lexisaurus
Is there any difference inside between ML and non ML radios?
Other than the ML branding is there anything electronically different? Obviously the amp and speakers are different but the head unit itself?
Thanks!
Share this post
Link to post
The head unit controls the ML amp and has the wiring connectors for it. I don't beleive they are interchangeable unless you are fitting the ML amp too.
Don't think you would gain anything if you were not fitting the amp too.
Share this post
Link to post
Thanks. Actually I was asking with the idea of the other way around... if I can source cheap ML amp and speaker upgrades then could I use with just the factory standard radio ....
Share this post
Link to post
I believe that you need the ML radio too.
On the one without the ML it would not have the controls to work the amp.
It switches the apm on and off and also sends only a pre amp signal to the ML amp
Share this post
Link to post
Loading...
