pappastratos Posted February 9, 2017 Share Posted February 9, 2017 Guys, my 2001 RX300 is having some issues. It's showing a open door, temp gauge not working, power locks not working, showing a 'open door' all the time. No dome light, climate control does not show anything. Earlier the dash was black, but later started working. Earlier the climate control temp guage was stuck on 75 degrees now just black. Driver window works ok, others do not. Seems to run ok. Any ideas ? I had a Camry that had issues like this & it was a broken wire at the door jamb. Quote Link to comment Share on other sites More sharing options...
TrevC Posted February 9, 2017 Share Posted February 9, 2017 You could attempt a battery reset to see if everything reboots to where it should be. Also, check the condition of the battery and terminal connections as this could cause all these electrical issues Quote Link to comment Share on other sites More sharing options...
pappastratos Posted February 9, 2017 Author Share Posted February 9, 2017 Ok, I will try that right now! Quote Link to comment Share on other sites More sharing options...
pappastratos Posted February 9, 2017 Author Share Posted February 9, 2017 Ok, no change, except the open door is off, but never comes on now. Also, the radio display is nlank. Radio does work. Any more thoughts ? Quote Link to comment Share on other sites More sharing options...
suzanspears62 Posted February 26, 2017 Share Posted February 26, 2017 Hi there, I am having the same trouble here. Seems to me it is a fuse or the computer. Did anyone figure out how to fix this? Quote Link to comment Share on other sites More sharing options...
TrevC Posted February 28, 2017 Share Posted February 28, 2017 I would still check the battery terminals so cleanliness and security. If they have corrosion or are loose then these symptoms are exactly what you would expect... Quote Link to comment Share on other sites More sharing options...
