Calikid13 Posted December 30, 2016 Share Posted December 30, 2016 I have a 1990 Lexus LS400 and the check engine light and bold failure light is on. When I disconnect my battery to clear red I'll start the car and it won't be on it will come back on only when I step on the break when I'm stopped. But I don't have any lights I need to be replaced. Would anyone have an idea what this could be? Quote Link to comment Share on other sites More sharing options...
Steve Posted December 30, 2016 Share Posted December 30, 2016 probably noting to do with the bulbs but possibly ABS or braking system itself. Also the CEL may be something different to the brake warning light. You need to get a code from the CEL and let us know what you get. Quote Link to comment Share on other sites More sharing options...
TrevC Posted December 30, 2016 Share Posted December 30, 2016 You could check the brake light switch is actually working...I believe there is a pad that drops off the pedal therefore not allowing the switch to be activated when the pedal is pressed...worth checking at least Quote Link to comment Share on other sites More sharing options...
Calikid13 Posted May 3, 2017 Author Share Posted May 3, 2017 Thanks I appreciate your help. And I have pulled the codes and the only one coming up is 78. And that's the O/D light blinking. Which believe is when u push the pedal all the way down it's not going far enough to activate the switch. I think. And then the check engine light won't even blink at all!! If there were no codes thought it would blink continuously. But doesn't even come on Quote Link to comment Share on other sites More sharing options...
Calikid13 Posted May 3, 2017 Author Share Posted May 3, 2017 Sorry that's code 68. Short circuit in kick down switch. But like I said won't pull check engine light codes Quote Link to comment Share on other sites More sharing options...
