The glove box in my 2004 LS430 is coming apart. The door you see facing the seat is separating from the inside part of the door. This causes the lock not to penetrate out of the back to latch. For the time being I put packing tape on the door to hold the two pieces together. With the tape, the latch works perfectly. I would rather fix the door with the correct clips or whatever holds it together. Any ideas?
I'm guessing the clips are what I highlighted in the attached diagram.  I suggest going to a Lexus dealership to verify.  The clips shouldn't be very expensive.
Thanks. I will try to take apart the door to access those clips. It sounds a bit challenging to get the door off.
