fernandolpa Posted October 11, 2016 Posted October 11, 2016 I have a RX300 2001 AWD. I need help to know how to disconnect the VSC and TRC systems. While driving off road, sand and snow, is better to turn it off. I read somewhere that the only ay is to take off the relay of fuse. Anybody has any other idea?
TrevC Posted October 12, 2016 Posted October 12, 2016 Hi Fernando...welcome to the Forum I'm not 100% sure but can't you temporarily switch off the VSC and TRC from inside the vehicle via a switch on the dashboard? It will then automatically default back to being switched on every time the ignition is cycled. Cheers Trevor
fernandolpa Posted October 12, 2016 Author Posted October 12, 2016 Hi Trevor, Switch is only present in the FWD model. I guess the only way is to disconnect something, somewhere... Thanks
TrevC Posted October 13, 2016 Posted October 13, 2016 I suppose you could wire a switch into the fuse supply to cut the power to the system for it to go offline
