doanhtran Posted August 17, 2016 Share Posted August 17, 2016 Does anyone know how to replace the transmission fluid on 2012 ES-350? If so, please provide instruction how to do it. Additional, what transmission fluid should be used on ES-350 when replace with new fluid. Quote Link to comment Share on other sites More sharing options...
TrevC Posted August 17, 2016 Share Posted August 17, 2016 Hi Doanh...welcome to the Club! To start with you'll need good access to the underside of the vehicle to drain the fluid and then the means to dispose of it. The correct type of oil is listed in the following link http://www.castrol.com/ and it is recommending 6.5 litres of fully synthetic fluid Hopefully some other members will know the exact procedure for replacing it. Cheers Trevor Quote Link to comment Share on other sites More sharing options...
