Bigflaco Posted June 19, 2016 Share Posted June 19, 2016 How to open trunk on my 1991 lexus 400 Quote Link to comment Share on other sites More sharing options...
Bigflaco Posted June 19, 2016 Author Share Posted June 19, 2016 My trunk won't open someone please help me I don't have master key and the button is pushed in on panel under steering column. Quote Link to comment Share on other sites More sharing options...
Exhaustgases Posted June 19, 2016 Share Posted June 19, 2016 Look around on the site here, others have just recently dealt with this too. Quote Link to comment Share on other sites More sharing options...
CELSI0R Posted June 20, 2016 Share Posted June 20, 2016 This thread will help you. The owner also could not open the trunk. Basically, bridge the terminals of the key trunk opener switch on the lower left of the dashboard to open the trunk. A search through the forums will provide a more detailed answer on how to do this, if you're not sure. Best of luck. Quote Link to comment Share on other sites More sharing options...
sha4000 Posted June 21, 2016 Share Posted June 21, 2016 Use the key or pull the lever that's near your left knee while your sitting in the drivers seat. Quote Link to comment Share on other sites More sharing options...
sha4000 Posted June 21, 2016 Share Posted June 21, 2016 That link leads to a thread with no real info. Quote Link to comment Share on other sites More sharing options...
CELSI0R Posted June 22, 2016 Share Posted June 22, 2016 Any luck, Bigflaco? I hope you have been able to solve this issue. To reiterate the instructions in the thread I linked earlier: access the connector on the backs of the key switch and the trunk release bridge the terminals of the key trunk opener switch on the lower left of the dashboard to open the trunk Here is another thread with the information on the terminals: remove the panel on the drivers side where the trunk and tank release levers are jump 12 volts to the trunk release switch under the dash by closing the circuit with a piece of wire [when you pull the lever it makes the contacts touch sending power to the switch which opens the trunk] Quote Link to comment Share on other sites More sharing options...
