replaced Transmission but problem not solved
friens3
Hi, I have an 2001 Rx300 AWD and the transmission is very rough shifting from 1st gear to 2nd, but it has no problem reaching 60mph
my Indy has replaced a new transmission , but the problem is still the same.
He has checked the ECU , no problem, and no error codes.
He also cleaned the speed sensor, knock sensor, neutral safety switch as suggested on the forum without success.
does anyone know where else to check?
that is a hard one to diagnose.  It is possible the rebuilt was not done correctly, and the tranny shop doesn't want to loose money.
  • 2 months later...
Believe it or not, the MAF affects the tranny shifting.  I had the same issue on my is300. Cleaning helped a little but replacing it fixed the shifting issues.  Rockauto has Denso parts for way less than the dealerships
