winter4w Posted May 12, 2016 Share Posted May 12, 2016 Hello, Sorry if this is posted in the wrong spot or something since this is my first post on this forum. So I got a 1996 ls400 with the XM snap for satellite radio. I was wondering how can I get the XM FM Direct adapter installed in my car? This is the direct adapter at best buy (http://www.bestbuy.com/site/siriusxm...=1158319078975). I did look at removing the stereo but the center wood panel seems to be in there good and I don't want to beak it. Also even if I do get it open and all setup how should I positions the wire so it can connect to my XM snap and look nearly invisible to others. If you have a setup or something is is possible if you can post pictures or a video? Thanks :D Quote Link to comment Share on other sites More sharing options...
winter4w Posted May 16, 2016 Author Share Posted May 16, 2016 UPDATE: Ok I was able to get the wood panel off but now I have ran into a new issue. I am not sure how to get the AC/Clock/Vents out so I can remove the top 2 screws of the radio. Can someone please post a way how to do it in a 1996 LS400. I did look at other videos but they are newer models or older models and one says to pry the ac off and others say to go inside and press a clip. If possible post images :) Thanks Quote Link to comment Share on other sites More sharing options...
sha4000 Posted May 19, 2016 Share Posted May 19, 2016 This should give you everything you need. http://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/661002-radio-removal-instructions-needed.html Quote Link to comment Share on other sites More sharing options...
