In the process of changing spark plugs and cables I noticed that the back side of throttle blade and intake tract from there back was coated with a black, thick gummy substance. :o I cleaned it with throttle body cleaner. Could this have been caused by a bad PCV valve? Anything else?
normal residue is black carbonm which is just a dry black soot
if it is gummy it is probably carbon and oil from an oil breather return line like that of the pcv which can stick open
