Ahc Suspension - Restricting It To Manual Setting
homeboy1
I have an 06 which seems to ride ok but AHC self adjusts at random - ie sitting at a stop light while driving on level roads/streets. Is it possible to eliminate the auto functionality entirely and only adjust manually when I want higher/lower ride height? How do I make it sit/stay where I want it?
  • 4 months later...
  • 6 months later...
The lock works well for the normal setting. If in any other, then the speed overide will reset the system to the normal setting when the speed setting is exceeded. The lock is best used when working on the vehicle with lifts and not when driving. If AHC is in the normal mode and noticeably adjusting at a stop light, there may be other issues with the system that need attention, such as a sensor malfunction or a leak.
