dbman Posted November 4, 2015 Share Posted November 4, 2015 Hi Guys, Thanks in advance for you help. I have a 2003 ES300 and the rear right window motor seems to be inoperable. The windows will not go down or up. I don't even hear a click on the motor when I press the button. I managed to see that the motor looks similar to other motors found in Toyota's such as the Camry and maybe other models. My local junk yard has many Toyota in various years and models, and I would like to know what other Toyota models if any , will be compatible with my ES300 . I think I will only need the motor, because the regulator is all metal and does not have a cable or plastic pieces to break or I could be wrong. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted November 5, 2015 Share Posted November 5, 2015 According to the parts cross reference at toyodiy.com , only the ES manufactured from 07/2001 through 02/2006 uses this particular regulator/motor assembly - part # 85720-33150. Quote Link to comment Share on other sites More sharing options...
VBdenny Posted November 10, 2015 Share Posted November 10, 2015 Check the switch too. Many times the switch goes bad. Quote Link to comment Share on other sites More sharing options...
