Hey Guys,
I've been lurking around the board for a couple of months picking up some really good information.
Time to put some $$$ into my 90LS400 with 135K miles. My wife still loves the car and will only part with it if I get her an '04 LS. So, I'm spending the $$$. :D
1) timing belt
2) LCD out (possibly Mikado)
3) replace air suspension (Strutmasters)
I plan to do the timing belt myself and wanted a good source for OEM parts.
"newlexusparts.com" apparently no longer works. Can someone recommend a good OEM source?
I plan to purchase the following:
1 timing belt tensioner
1 right timing belt pulley
1 left timing belt pulley
1 timing belt
1 aux belt
2 crankshaft seals
1 camshaft seal
1 water pump
Thanks 99, I'll check out lexus-parts.com.
The 04 is nice, but I'll have to replace the 4x4 first. I figure if I put $2K in the car I might be good for another 60K mls.
If others have any additional sources for OEM parts I'd welcome the input.
CC
:lol: Another 60k? I'm at 226k(95), and mechanically the car is in tip top shape! I plan on atleast 400k out of this car! My car needs its second timing belt soon, so I'm going to order from newlexusparts.com. I just tried their website; it is fine for me. Try this link to newlexusparts: http://www.trademotion.com/partlocator/ind...990&catalogid=1 . Let me know how bad the timing belt service is; I can't decide if I want to do it myself or not. Hope this helps!
:cheers:
why 2k? engine rehaul parts are around 500$ only how much is the air suspension?
why dont u convert to regular suspension?
VMF
Timing belt: $500-$600
Strutmaster: $750
New tires: $200 (haven't priced them yet)
LCD: $250 (mikata)
Should probably change dist cap and wires
Adds up pretty quickly. I took it to the Lexus "stealer" for a full checkup and they told me it needed $10K...$4K suspension....$1350 service...etc. Basically $5K in parts and $5K in labor. Then they got p*ssed when I told them thanks, but no thanks. Most of what they said didn't make sense.
blake918-....226K???? that's pretty impressive. I tried your link and it works!
