Jim Walker Posted April 20, 2003 Posted April 20, 2003 Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well. The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too. 2
moune Posted July 15, 2004 Posted July 15, 2004 I am also having a problem with my instrument cluster, the RPM guage doesn't work anymore. It stopped working after I hit a huge pot hole. I think it's just something loose or got disconnected. If you can please email me the instructions on how to take it apart and check. thanks My email moune186@yahoo.com
pcoombes Posted September 18, 2004 Posted September 18, 2004 I have both issues so if anyone that has any information on either topic can email me I would be very grateful. Thanks, Pete pcoombes@excelswitching.com
michaelg Posted August 28, 2005 Posted August 28, 2005 I dont have the light problem but my temperature guage doesnt work. it stays pegged at hot. do you know how to repair? Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well.The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too. ← 1
misshooty Posted September 25, 2006 Posted September 25, 2006 Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well. The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too. My dash is completely out except when I start my car. The pointers flicker and all of the sensor lights light up but I have no idea how much gas I have or how fast I am going..(not good for a girl with a bit of a lead foot). I have a '93 LS that I love but don't want to spend thousands to repair the dash. I am in the Indianapolis area if you know of anyone here, but I would also love to have the info on repairing it. I can get a friend to help me. Thank you soooo much!!!! My email is misshooty2004@yahoo.com
VBdenny Posted October 15, 2006 Posted October 15, 2006 Jim, I'll bet if you ask SK or one of the other moderators maybe they can still add it to this section in spite of the limit. This is a great service you have provided and through the years I know you have helped many people here. I would love to have a copy even though I don't have this problem. Denny and I forgot.... Michael, are you SURE it is not that you really are running hot? My brother had a waterpump impeller break one time and he thought it was the gauge but it wasn't. Just a thought since if it breaks it seems the gauge would rest on C
SPEEDYPETEY52 Posted January 20, 2007 Posted January 20, 2007 Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well. The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net thanks jim any help would be greatly appreciated you can e- mail to speedypetey52@yahoo.com -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too.
logic Posted March 14, 2007 Posted March 14, 2007 Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well. The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net Hi, do you know where to get those two oval shaped flourescent bulbs that go in the instrument cluster to light up the speedometer and tach gauge? -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too. My dash is completely out except when I start my car. The pointers flicker and all of the sensor lights light up but I have no idea how much gas I have or how fast I am going..(not good for a girl with a bit of a lead foot). I have a '93 LS that I love but don't want to spend thousands to repair the dash. I am in the Indianapolis area if you know of anyone here, but I would also love to have the info on repairing it. I can get a friend to help me. Thank you soooo much!!!! My email is misshooty2004@yahoo.com Hi, do you know where to get those two oval shaped flourescent bulbs that go in the instrument cluster to light up the speedometer and tach gauge?
Jim Walker Posted March 14, 2007 Author Posted March 14, 2007 Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well. The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net Hi, do you know where to get those two oval shaped flourescent bulbs that go in the instrument cluster to light up the speedometer and tach gauge? -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too. My dash is completely out except when I start my car. The pointers flicker and all of the sensor lights light up but I have no idea how much gas I have or how fast I am going..(not good for a girl with a bit of a lead foot). I have a '93 LS that I love but don't want to spend thousands to repair the dash. I am in the Indianapolis area if you know of anyone here, but I would also love to have the info on repairing it. I can get a friend to help me. Thank you soooo much!!!! My email is misshooty2004@yahoo.com Hi, do you know where to get those two oval shaped flourescent bulbs that go in the instrument cluster to light up the speedometer and tach gauge? Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well. The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net Hi, do you know where to get those two oval shaped flourescent bulbs that go in the instrument cluster to light up the speedometer and tach gauge? -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too. My dash is completely out except when I start my car. The pointers flicker and all of the sensor lights light up but I have no idea how much gas I have or how fast I am going..(not good for a girl with a bit of a lead foot). I have a '93 LS that I love but don't want to spend thousands to repair the dash. I am in the Indianapolis area if you know of anyone here, but I would also love to have the info on repairing it. I can get a friend to help me. Thank you soooo much!!!! My email is misshooty2004@yahoo.com Hi, do you know where to get those two oval shaped flourescent bulbs that go in the instrument cluster to light up the speedometer and tach gauge? Yes, I have those oval lights, but chances are they are not bad. There are other reasons for those not to light up. Email me directly so I can send the info. jimlwalker@sbcglobal.net 1
Paul A Posted October 27, 2007 Posted October 27, 2007 I have a 92 LS400 that in the last month the light on the needle of the speed guage is half out or black, but only half of the needle. Not sure what this is all about. For a few years now the LCD the you read temp & clock is dark and you can't read, but the LCD fpr the radio/CD is fine. Paul
nickbroadhead Posted June 9, 2008 Posted June 9, 2008 Hi my name is nick and i have a 1993 LS400 and the gauges do exactly what you are describing. I would love to know how to fix it. Please send me directions. Thanks! Nick
MA56 Posted June 21, 2008 Posted June 21, 2008 I have a 1996 LS400 and I am having a problem with the speedometer not working in the morning but it eventually starts working after driving about 10 miles. Would this fix also help my problem? I would like to have the instructions if it would fix my problem. Thanks for any help you can give me. Mary
ShereeJane Posted October 15, 2008 Posted October 15, 2008 Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well.The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too.
janne Posted November 19, 2008 Posted November 19, 2008 Hi my name is Janne å and i have a 1994 LS400 and the gauges do exactly what you are describing. I would love to know how to fix it. Please send me directions. Thanks! My email is jan_aberg_7@hotmail.com
turbo4546969 Posted November 19, 2008 Posted November 19, 2008 Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well.The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too.
turbo4546969 Posted November 19, 2008 Posted November 19, 2008 Hey JIM, there is A god after all! I have already pulled the insturment cluster out. would like to know if capacitor or what is problem. It will definately be appreciated! Stanley Fraticelli E-mail is turbo4546969@gmail.com
turbo4546969 Posted November 19, 2008 Posted November 19, 2008 Hey JIM, there is A god after all! I have already pulled the insturment cluster out. would like to know if capacitor or what is problem. It will definately be appreciated! Stanley Fraticelli E-mail is turbo4546969@gmail.com Dallas,TX.
downsy Posted January 21, 2009 Posted January 21, 2009 Could you please send me the information regards to the lexus. thanks STEVE@RS250.WANADOO.CO.UK
downsy Posted January 22, 2009 Posted January 22, 2009 :( My panel has died exactly as you have described could you please e-mail the solution to:- peter @dalcocaraudio.co.uk Kindest regards Pete Lowestoft Suffolk England
Fuller Posted January 29, 2009 Posted January 29, 2009 Hi Jim- I have a 95 SC400, the dash lights are partially out. It might helpful for me to use your instructions. Thanks, Mark fullerm410@msn.com Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well.The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too.
shorttacks Posted February 2, 2009 Posted February 2, 2009 i have a 1993 lexus ls400. i also have the same problem. please email me the instructions to correct this problem.i am trying to get the car inspected but i cant get the lights to come on when i have an appointment.they only come on when they want to.the dash lights are my only problem with this car and i really need to get it inspected.my email is shorttacks@cox.net. thank you very much. kristie
inventone Posted February 6, 2009 Posted February 6, 2009 Hi Jim my name is paul and i'm in new orleans could you send me info. on how to fix my dash lights on my 94 LS4000 my email is inventone@aol.com thanks alot!
rob ls400 Posted February 19, 2009 Posted February 19, 2009 my dash lights in my 94 ls400 do not light up.can you help me .my email is roserkaj@aol.com. thanks rob
XXIIAJC Posted March 5, 2009 Posted March 5, 2009 Lexus LS400 '93 and '94 have a problem with the instrument cluster lights (dash lights). Many many people have this problem. The dash lights won't come on for a while, then they will flicker and finally come on. This is more evident in cold weather. This problem gets worse over a period of weeks or months until they will refuse to come on at all. When the light are off, the fuel gauge points to empty as well.The problem, I found, is in the power supply circuit boards. They are located behind the instrument cluster. I have compiled some detailed instructions on how to remove those boards. If you want a copy of those instructions, just Email (PM) me. I'll Email them to you, no charge. I would attach them here, but they are larger than the 102.4KB limit on this board. My car did that. '93 LS400. The Lexus dealer wanted $1400 to repair it. I repaired mine myself, I'm an electronics engineer and I can help you repair yours too! Email me or PM me Jim Walker jimlwalker@sbcglobal.net -------------------- I have the Repair for your '93 or '94 LS400 flickering INSTRUMENT LIGHTS! I'm an electronics engineer and have found the solution to this common problem on my own car! I want to help you with your problem too.
Rolik Posted April 2, 2009 Posted April 2, 2009 Hi Jim ! I have 1993 Lexus LS 400 V8 My dashboard lights flicker on and off constantly sometimes the dash goes completely black. Cant see anything and don't know how much gas I have and how fast I am going. Dashboards lights do not work on cold/damp mornings until the car warms up, Takes about 50 miles to drive in cold weather and 5-10 miles when it's warm. Dash lights never turn on until the temperature reaches good temperture. Also I have problem which my ODO, sometimes it's mixed up . Is there way to display correct ODO?? Any help would be most appreciated. Would you please send me instructions,how to solve the problem ! Thank you very much !
