Jacking Up A Gs300
Which points in which manual are you referring to? The 4 points on the side of the car in the owner's manual? Or the two in the middle of the car in the service manual? Which ones are not convenient?
If you have a floor jack and are not lowered or have a kit that will hinder a jack from getting to the middle of the car, you can use the suspension cross member in the front or the differential in the rear as jack points.
