Lowering With 19's
I just purchased a set of 19x8.5 +42 up front and 19x9.5 +45 out back for my '98 GS400. My question is, if I use the Eibach Pro-kit, will there be a problem with rubbing on the front wheels. I know the preferred offset is around 35-38 but I couldn't pass up this deal. Any help will be much appriciated.
Thannks
Nick
EDIT: I am running a 245/35/19 and 275/30/19 if that helps any
Here is a picture of the car
You shouldn't have a problem rubbing..
Thanks for the info. I thought that it would like OK without lowering but once I put the wheels on it was obvious that it need to be lowered an inch or so. As for the Eibach springs, do they settle much past an inch. I have had several Honda's in which I have installed Eibachs and they settled way past what they claimed.
Thanks in advance,
-Nick
