A Question About The Hood Latch
Exhaustgases
Has anyone ever had to deal with a broke cable, broke hood latch? If so what did you do to open it?
On this new to me ls400 a 92, sometimes the release handle will not return to its locked position. I want to be prepared just in case.
The "sometimes" is interesting. If it works sometime, it's not broken. Before I got into expensive stuff, try to get some lubrication into the cable and hood points. Could just be a cable hanging up a little if you are lucky. Welcome.
I've studied it a bit. And of course with the grill in the way it wouldn't be easy. But if it will !Removed! to the back some when the mounting bolts are removed then as long as its not the hood latch frozen and just a broke cable. Then you could snare the lever that the cable connects to with some tough line or wire and use it to pull on you would likely need a flexable video scope to see things.
