russhog1989 Posted August 20, 2014 Share Posted August 20, 2014 I can't find where this issue was solved. Replaced alt. Not sure if problem occurred before or after that. No radio, telescoping steering, door locks, interior lights, mirror, shift release, truck unlock. Any idea. i pulled round relays under dash and put back in, no result. Quote Link to comment Share on other sites More sharing options...
LSPaul Posted August 21, 2014 Share Posted August 21, 2014 Did you check the fuses under the hood (including the maxi-fuses/fusible links)? Paul Quote Link to comment Share on other sites More sharing options...
dcfish Posted August 21, 2014 Share Posted August 21, 2014 It is the wiring in your trunk hinge...Search the Forums for your answer :) Quote Link to comment Share on other sites More sharing options...
