Hello Everyone - Was hoping to get a little insight on what might be the problem with my 1999 GS300 that has a problem with stalling.
I am thinking it is a TPS issue or some sort of sensor. Thank you for the help!
Problem
- Car stalls when i come to a complete stop at a stop light or standing idle.
- If the car stalls I generally have to floor the gas to get it to start again. From that point to keep it running i have to feather the gas over 1200rpm.
- When i can feel the car starting to choke, I put the car in neutural and try to give it gas. Sometimes it responds, sometimes it does not then stalls. From this point, I start back at point 2.
- When car stalls it feels like it is choking for air.
Syptoms
- Noticing a little bit of a rough idle at first start of the day
- Idle to me seems a little low
- Car runs fine when gas is being applied
- I live in Las Vegas where current temperature is usually 95-105 degrees. I notice the car tends to stall more often on hot days.
- The problem occurs only after running the car around town for an hour or two. Again, seems to happen often on hot days.
Car condition
- In good shape with - 167K miles
- Plugs and wires replaced 10K miles ago
- Fuel pressure regulator replaced 10K miles ago
- Timing belt changed 20K miles ago
- Regular maintenance completed
- Good battery and alternator
