Moh153 Posted June 4, 2014 Share Posted June 4, 2014 Hi people I'm the proud owner of a 2004 silver LS430 here in UK Loving the drive on it. Awesome machine. But I have a problem with the reverse camera which does not work Just a blank screen when it's in reverse Just got the car and previous owner said he forgot to plug in the camera connector in the head unit, so I had the unit and everything else out but could not find the cable/connector at all behind head unit Any help much appreciated Thanks Moh Quote Link to comment Share on other sites More sharing options...
Robert Young Posted July 10, 2014 Share Posted July 10, 2014 The camera plugs into a separate Television Camera ECU, located on the upper right side of the trunk area. The wiring diagram shows it under (outside, to the right of) the stereo amp. There are four wires from the camera to the Television Camera ECU; they look to be video +, video -, battery power and ground. The signal path for the Television Camera ECU goes through several other ECUs before it gets to the nav display screen. Quote Link to comment Share on other sites More sharing options...
