mjfuture Posted May 27, 2014 Share Posted May 27, 2014 Hi there, Whenever I turn on the A/C the rpm rise as the compressor start which is normal... but somehow it delivers the power to the wheels also in short: compressor click = race pedal automatically activated I hardly feel it when I pass 65 kph (40 mph) but under that it's really annoying.... especially here in Bahrain where is the longest drive without braking never exceed 15 minutes which is very rare I one let it go from 0 kph with the a/c on... once the compressor clicked I released the brake and it's almost reached 30 kph (18 mph) I'll try to upload a video ASAP any suggestion would be appreciated THX Quote Link to comment Share on other sites More sharing options...
mjfuture Posted May 27, 2014 Author Share Posted May 27, 2014 opps forgot the fuel economy I used to get about 14 - 16 L/100KM (16 - 14 mpg) estimated but now 20 - 25 L/100KM (11 - 9 mpg) PLZ HELP!!! it's 95 ls400 Quote Link to comment Share on other sites More sharing options...
sha4000 Posted May 27, 2014 Share Posted May 27, 2014 Is your check engine light on? that's terrible gas mileage if I understand you correctly. Quote Link to comment Share on other sites More sharing options...
mjfuture Posted May 28, 2014 Author Share Posted May 28, 2014 no no warning lights!! the a/c and mileage issue are separated a/c thing been like forever but the mileage less than a year I read this before http://www.clublexus.com/forums/ls400/377171-diy-coolant-temperature-sensor-change-pics.html I'm going to replace it but i need to know if anything else could be the effect Quote Link to comment Share on other sites More sharing options...
landar Posted May 29, 2014 Share Posted May 29, 2014 Generally speaking, poor gas mileage means a rich mixture of fuel/air. And usually due to a "cool" running engine or a computer that 'thinks' the engine is running cool. A bad coolant temp sensor could be telling the computer to increase the fuel mixture all of the time. Or, perhaps, your engine really is running too cool such as a bad (stuck open) thermostat could cause. I suppose bad O2 sensors could also wreak havoc on your fuel trim. Quote Link to comment Share on other sites More sharing options...
Chicken Posted May 30, 2014 Share Posted May 30, 2014 same issue here when it comes to MPG. A full tank of gas only lasts me 250miles in the city and around 300-325 on the highway. Doesn't matter if I use high octane ( 91 ) or premium ( 89 ). Quote Link to comment Share on other sites More sharing options...
sha4000 Posted May 30, 2014 Share Posted May 30, 2014 same issue here when it comes to MPG. A full tank of gas only lasts me 250miles in the city and around 300-325 on the highway. Doesn't matter if I use high octane ( 91 ) or premium ( 89 ). Do you have any check engine codes? You should be getting upward of 400 miles on a tank if the car is running properly. What year do you have, miles on it and when was the last time you had a tuneup? Quote Link to comment Share on other sites More sharing options...
Chicken Posted May 30, 2014 Share Posted May 30, 2014 same issue here when it comes to MPG. A full tank of gas only lasts me 250miles in the city and around 300-325 on the highway. Doesn't matter if I use high octane ( 91 ) or premium ( 89 ). Do you have any check engine codes? You should be getting upward of 400 miles on a tank if the car is running properly. What year do you have, miles on it and when was the last time you had a tuneup? No Check engine light. Got 126k Miles on it, oil changed ( regular, not synthetic) every 3000 miles or so. I've considered selling it , but it's only been less than a year since I bought this car. Quote Link to comment Share on other sites More sharing options...
sha4000 Posted May 30, 2014 Share Posted May 30, 2014 Do you mean your car will accelerate on it's own or that the rpms just go higher while in park?Sign up on the other lexus forum and post your problem. You might get more suggestions over there. http://www.clublexus.com/forums/ls400-183/ Quote Link to comment Share on other sites More sharing options...
mjfuture Posted June 9, 2014 Author Share Posted June 9, 2014 Hi guys Do you mean your car will accelerate on it's own or that the rpms just go higher while in park?Sign up on the other lexus forum and post your problem. You might get more suggestions over there.http://www.clublexus.com/forums/ls400-183/ yes the car will accelerate on it's own whenever i turn on the acdone that alreadyhttp://www.clublexus.com/forums/ls400/743825-a-c-fuel-consumption-ls400-95-a.htmlbut i'll try to keep both posts updated Quote Link to comment Share on other sites More sharing options...
mjfuture Posted June 9, 2014 Author Share Posted June 9, 2014 I replaced the coolant temperature sensor two days ago.... but haven't notice any changes yet next i'll change the gear oil btw lander... there is no O2 sensor on gcc models Quote Link to comment Share on other sites More sharing options...
