ididit Posted May 1, 2014 Share Posted May 1, 2014 in the past week, I notice that my car began to make some noise when I accelerated the car. Then when I turn on the car, if the car make some unusual noise, I can see white steam coming out of back pipe (not every time). I did search online and found it's like exhaust leaking problem. Then today, when I try to turn it on, it just make some noise like gas leaking.I made 2 youtube clips for reference. Any suggestion? 1st clip: from driver side https://www.youtube.com/watch?v=UOHmZarxgAI 2nd clip: from front of the car https://www.youtube.com/watch?v=b4OjHxbAGlI Quote Link to comment Share on other sites More sharing options...
lenore Posted May 1, 2014 Share Posted May 1, 2014 That sounds bad. Did you check the engine oil? Sounds like something broke, maybe the timing belt and you have something major going on....Or maybe something simple. Maybe the starter is shot and not cranking the engine. Have a helper turn key and see if the belts are moving. Quote Link to comment Share on other sites More sharing options...
ididit Posted May 5, 2014 Author Share Posted May 5, 2014 just change the starter contact. now, there is no broken noise, only air leaking kind of noise. I upload another video on youtube. https://www.youtube.com/watch?v=XsbVihtRUR4 UPDATE: just change the whole starter. now it's normal. Quote Link to comment Share on other sites More sharing options...
