mudkeith Posted March 2, 2014 Share Posted March 2, 2014 got a 03 rx300. the cel came on code p0135. replaced the sensor and the code came right back. swapped bank one with bank two and same thing anyone have ideas? Quote Link to comment Share on other sites More sharing options...
mudkeith Posted March 4, 2014 Author Share Posted March 4, 2014 Pulled codes with a obd book got a hold of a solus going to try that. Quote Link to comment Share on other sites More sharing options...
lenore Posted March 4, 2014 Share Posted March 4, 2014 Did you use Bosch or Denso sensors....? Denso only.... also check your flex pipe to see if it is cracked. Quote Link to comment Share on other sites More sharing options...
mudkeith Posted March 5, 2014 Author Share Posted March 5, 2014 Denso and thanks I will check the pipe Quote Link to comment Share on other sites More sharing options...
mudkeith Posted March 7, 2014 Author Share Posted March 7, 2014 Same open circuit going to ohm the wires from the ecu to the 02 plug Quote Link to comment Share on other sites More sharing options...
lenore Posted March 7, 2014 Share Posted March 7, 2014 The two sensors I believe are wired in series on the heater side, so If one has a open heater, than both do. Quote Link to comment Share on other sites More sharing options...
mudkeith Posted March 15, 2014 Author Share Posted March 15, 2014 Ok ohmed all the wires from the sensor to the ecu and all is good. I think the dealer screwed the ecu when a new key was programmed? The ck eng lt came on after it was programmed. Quote Link to comment Share on other sites More sharing options...
mudkeith Posted March 15, 2014 Author Share Posted March 15, 2014 Thinking about getting a used ecu off ebay. Quote Link to comment Share on other sites More sharing options...
