Hi all,
I hope my experience would help someone with the same problem.
I have been trying to fix the vibration on acceleration for sometime and then I gave up. I went to StevensCreek Lexus, San jose (CA) because I thought if I were to buy the 2 flexible couplings which are the rubber parts most likely to fail after 420.000 miles, then I have to have Lexus to balance the propeller shafts after replacement. Labor cost might be high.
But finally the problem was only the center support bearing of the 2 propeller shafts ( part # 37230 30160 ).
I was so happy that the vibration gone.
  • Like 1
Good to know and glad you got the vibration issue resolved. Thanks for posting the solution, Don. :cheers:
