jamestuj Posted December 31, 2013 Report Share Posted December 31, 2013 All, Suddenly I had those unrelated issues together yesterday afternoon from my 2002 Lexus LS 430: 1. remote key could not lock or unlock the doors 2. inside the car, could not open the trunk door, could open manually with the remote key 3. inside the car, could not open the gas door, had to open the trunk and pull the rope 4. inside the car, power door lock not working, could not open other side windows, except the driver side window 5. could not adjust both side mirrors 6. if leave the headlights on auto, lights would stay on after turning off the car and locked the door. all other works and no issue driving. checked all 6 fuse boxes, no issue. The funny thing was that around 8 pm, all worked and back to normal. This morning, all worked, around 2 pm, all issues resumed. I had battery died a week ago, AAA checked and no issue with the battery, might leave the radio on too long the night before without starting the car. Had a custom Kenwood radio/back camera combo. Please help. 1 Quote Link to comment Share on other sites More sharing options...
jamestuj Posted December 31, 2013 Author Report Share Posted December 31, 2013 forgot, a few times, when I started the car, alarm would go on. Also I reset the vsc light off successfully (due to smog check) the other day by shorting the pin 3 and 5 per forum instructions. Quote Link to comment Share on other sites More sharing options...
Pittgt98 Posted May 9, 2014 Report Share Posted May 9, 2014 James I'm working on a car at this very moment and its having the exact same issues. Would greatly appreciate any advice or help thanks David. Quote Link to comment Share on other sites More sharing options...
Robert Young Posted May 13, 2014 Report Share Posted May 13, 2014 Just a thought, but try forcing everything without stable memory to reset. First, make sure the battery positive connection is good. Then disconnect the battery ground for at least 30 seconds and replace it with quick / firm contact with the battery (no multiple arcs). Somewhere in the owners manual there is a list of things you then need to reset, such as moving the seats to the end of range to calibrate the memory. I just did a quick look and could not find the right section, so it might be somewhere not obvious. Quote Link to comment Share on other sites More sharing options...
Jeb Bartley Posted June 6, 2016 Report Share Posted June 6, 2016 Please help I just had the same problem, any ideas? Quote Link to comment Share on other sites More sharing options...
