Hi!
Is there anybody who had to replace the driver side servomotor? I was told by a dealer It cost lot of money as they got to remove the dashboard. Part is not costly but the labour. I want to make sure whether it is true. Thanks.
What is the servomotor for? Not sure I understand what part of the car you are talking about.
It helps to mix the hot air & cold air according to the information from climate control. Motor controls the opening with a damper connected to it. There are two motors for Driver side & passanger side, which are bit difficult to reach under the dash board.
Look at this link to get an idea of a different car http://www.clublexus.com/forums/gs-second-generation/501372-diy-repairing-air-mix-servomotors.html
Thanks for the interest.
Yes, you have to remove the whole dashboard, steering wheel, and front wipers/cowl according to the service manual to get to the A/C parts.
