sbushnak Posted September 23, 2013 Posted September 23, 2013 Hey all,I need some help with my friend's 2002 GS300 heater. It has 170K milesProblem is that the heat is only working on the passenger side and not the driver side.I did some research and read about the servo motors for the driver side.We got it out and it seems to be working perfectly. It moves as you change the temperature for the driver side.I tried to move the white arm by hand and still the air coming from the driver side is lukewarm at best. It is definitely no where near 85 when we set the climate control.Now the A/C will work on both sides with no problem and the heater is working great on the passenger side.My next step is to check the other 3 servos on the passenger side to confirm they are all working.More info about the car:170K milesRadiator + thermostat replacedWe flushed the coolant last week and will do so again this MondayBoth heater core hoses near the firewall are hotIf you need anything else please let me know.Can anybody help with any advice or what should we do next?Thanks in advance!
WOOF98 Posted October 7, 2013 Posted October 7, 2013 froggy has a bunch of lexus air door/blend/ fix your servo ytubes on his channel Start here
