Stuck in the middle of nowhere. Flat tire but can't unscrew one of the nuts which has a smooth head and looks totally different than the others...is it a wheel lock or what??....what tool do I need. I am not impressing my new girlfriend here. HELP
YES - it's a lug nut lock. The "key" SHOULD be in the vehicle somewhere (famous last words). To be perfectly honest, I'm not sure where mine is. I've been lucky, never had a flat, and my dealer has always rotated the tires.
Good luck finding it. You might try calling the dealer where it was serviced and ask where the techs usually put it.
I believe the key is in the back where the tire-changing tools are. The manual that is linked in one of the stickies, above should contain info about this.
