1991 Ls-400 Air Shock Failure
Fogcity
Can anyone help me with the best replacement "Manual Shock" for the front, ...the back air shocks seem to be holding up with no leakage,.... Is it possible to Just replace the front Only.? Thank You Very Much.
You could I guess just replace the fronts but then you will have to block off the front air lines and trick the AS system into thinking there are still air struts all around.
Why don't you just convert the lot to springs and do away with the air?
http://www.lextreme.com/ascon.html
  • Like 1
